Time to get the engine out of there:
Getting the engine out involved dropping the front of the car until the engine sat on the dolly, strapping the engine down, removing engine mounts, lifting the front, and rolling the engine out. Easy
Lets have a look inside:
Cylinder walls showed some wear...
Yikes... look at these pistons - rebuild just in time:
Hey... lets upgrade the suspension while I'm at it:
Might as well clean the engine bay while I can:
My original sleeves have seen enough action... lets do this:
83mm pistons and sleeves installed:
Head was reworked by 4 Piston Racing - combustion chamber looking good - had to open it up a pinch for the pistons
Look at those ports:
Engine back from builder (Lawrence Built)
And she's back in:
Time for the first round on the Dyno:
Not a bad result from the first day:
Found a problem with my ignition on the Dyno, so I've since upgraded to Coil Pack Ignition and will head to the dyno for round 2. I believe there is some power still left in there
Build details:
Top end stuffs:
- 4 Piston Racing Outlaw CnC head
- Skunk2 Pro series valves and valve train
- Skunk2 Pro2 cams
- Skunk2 cam gears
- Skunk2 ultrastreet IM
- 4 Piston Racing CnC porting on Skunk2 IM
- Skunk2 70mm TB
- Mugen intake
- Samco intake pipe
- Skunk2 composite fuel rail
- Grams 550cc injectors
- Skunk2 Mega Power Header
- Skunk2 has 3" exhaust
bottom end stuffs:
- Wiseco 83mm 8cc pistons
- Carrillo Pro-A ultralight rods
- 4 Piston Racing high RPM oil pump
- lightened ITR crank
- ATI harmonic dampener
- Aluminum Flywheel
Tuning:
Hondata S300
Hondata Coil Pack Retrofit
