Question about spark plugs
Hakjai
Badge Number: 98-0718
Post by Hakjai » Thu Apr 15, 2021 4:45 pm
I did a search and read a few threads about spark plugs but the info on spark plugs out there got me even more confused.
OEM: 98079-5614H ($17/each) https://www.acurapartswarehouse.com/oem ... 5614H.html
Also called: Pfr6G-11 ($11.79)
Also known as: NGK-5555 https://www.ngk.com/ngk-5555-pfr6g-11-l ... spark-plug
I've seen people say they use: BKR7E-11 plug which is a V Power plug ($2.39)
But the NGK website says the V Power plug compatible with our cars is: BKR6E-11 NGK-2756 https://www.ngk.com/ngk-2756-bkr6e-11-v ... spark-plug
What spark plugs are you guys running right now?
Re: Question about spark plugs
Post by coolhandluke » Fri Apr 16, 2021 1:40 pm
I recently switched based off feedback from RBoosted717 to:
-BKR7E (4644)
Note, these plugs work well with stock to higher compression setups. The plugs I previously ran different plugs per a tuner's rec but they were better suited for forced induction / high CR setups.
Hakjai
Post by Hakjai » Fri Apr 16, 2021 4:10 pm
coolhandluke wrote: Fri Apr 16, 2021 1:40 pm I recently switched based off feedback from RBoosted717 to:
-BKR7E (4644)
Thanks so much for the info! FCP Euro has these for $2.52 which is perfect. I needed to order something from them anyway.
https://www.fcpeuro.com/products/vw-aud ... e-ngk-4644
It's odd the BKR7E isn't listed as compatible with our cars though.
