Easy Fixes: Gauge Cluster & Exhaust Rattles
touringteg
Re: Easy Fixes: Gauge Cluster & Exhaust Rattles
Post by touringteg » Wed Jun 13, 2018 2:27 pm
My hatch rattle came back :( The culprit is definitely that plastic panel on the hatch just below the glass. Just not sure what to do with it yet. I'm afraid it will break if I take all the pieces off.
Post by aw614 » Thu Jun 14, 2018 8:09 am
I think my hatch started rattling just recently, it isn't that loud, but it sounds like something is loose. I pushed something in and it seems to have disappeared, but I need to empty my car to be sure.
Im starting to think my shifter rattle might not be the heatshields...has anyone run the mfactory bushings and/or energy shift bushings? Do they typically induce more cabin rattle at the shifter? Im also using Spoon Engine mounts which supposedly are slightly stiffer than stock
DC2Iggy
Post by DC2Iggy » Fri Jun 15, 2018 8:08 am
touringteg wrote: Wed Jun 13, 2018 2:27 pm My hatch rattle came back :( The culprit is definitely that plastic panel on the hatch just below the glass. Just not sure what to do with it yet. I'm afraid it will break if I take all the pieces off.
Try adding some foam tape around the plastic bits and even the clips. This should make everything more snug and you won't have any metal on plastic contact. This is how I solved the same rattle on my STI hatch.
touringteg
Post by touringteg » Fri Jun 15, 2018 12:03 pm
^ thanks !
