ayau
Post
by ayau » Tue Oct 10, 2017 2:56 pm
voiddweller wrote: ↑Tue Oct 10, 2017 12:16 pm
The point of getting the CTR (in my case) was so I wouldn't need to do anything except add pads, high temp fluids, and normal 'HPDE' maintenance. This was wishful thinking. It's still a good car but Honda might have oversold it a bit
After researching HPDE overheating issues and solutions, I've decided that there are a couple simple changes that might make a difference: Water Wetter and (to a lesser extent) engine oil. Temperature and humidity are starting to decline in Pittsburgh, so I probably won't know the impacts for a while unless I decide to take the car down to Sebring in the Spring. If the high heat issues are resolved, I'll move down to 18" wheels and tires to keep the durable costs in check.
More involved solutions that I've read about, but shouldn't be difficult to do, are adding a larger radiator and oil cooler. There are still not a lot of aftermarket choices and only a few people posting their HPDE data.
I may forgo touching the engine bay and run the heater at full blast with some air duct extensions on the floor heater vents that route the heat way from the driver's feet. Not my first choice, but this should keep the water/oil temperature in check without burning my ankles as long the parts don't interfere with the pedals. I'll need to figure out a safe clamping mechanism that will hold firm and be easy to remove.
Dave is looking into getting a Camaro 1SS with the track pack due to similar issues (in addition to differential cooling) with his Focus RS.
Once things settle down at work and I'm motivated enough, I'll see about getting in one more track day before the venues close.
It doesn’t look like a larger radiator will be a real fix.
Apparently Honda tested a larger radiator and that didn’t fix the heating issue.
http://www.civicx.com/threads/prl-motor ... ost-295119
I think a lot of air is blocked by the black piece (near the front emblem.
voiddweller
Post
by voiddweller » Wed Oct 11, 2017 10:24 am
Good to know.
Is there confirmation of an OEM oil temp sensor that can be accessed or is an aftermarket sensor needed?
'19 ZLE, '12 MDX, '04 TSX MT,
ayau
Post
by ayau » Wed Oct 11, 2017 10:27 am
voiddweller wrote: ↑Wed Oct 11, 2017 10:24 am
Good to know.
Unfortunately no OEM oil temp sensor. Just an OEM water temp sensor.
Post
by Dave7CDMTYPER » Wed Oct 11, 2017 2:27 pm
ayau wrote: ↑Tue Oct 10, 2017 2:56 pm
Maybe they shouldn't have put so many FAKE vents, at least.
Zyg
Post
by Zyg » Fri Oct 13, 2017 7:46 pm
Dave7CDMTYPER wrote: ↑Wed Oct 11, 2017 2:27 pmMaybe they shouldn't have put so many FAKE vents, at least.
Please state which "vents" you think are "fake", and why you think so!
P.S. Official member of the on-track fuel starvation/rev match/check engine light P0035.
Post
by Dave7CDMTYPER » Fri Oct 13, 2017 8:44 pm
Zyg wrote: ↑Fri Oct 13, 2017 7:46 pm
Lol. Well I'm mainly referring to the black fake vent/inlets around the fog lights on the front end. They should put some real vents there and maybe it will help solve the problem! If the CTR could talk, I bet it'd be pissed that it has those fake vents. And the ones on the back too.
Zyg
Post
by Zyg » Thu Oct 19, 2017 4:35 pm
Went out in my last session on track with ~ 1/4 - 1/3rd of a tank of fuel, and a few laps in I'd thrown a check engine light
with a couple of main dash display messages ( 1) and 2) below.
Greg in the red CTR at Mid-Ohio was able to successfully reset the only trouble code of P0035 ... Turbo Charger Bypass Valve Control Circuit High, visually checked wiring/plug.
About 30 miles down the road/highway the CEL and warnings came back up during cruising w/traffic @ 70, displaying CEL and:
1) Rev Match System Problem
2) Emissions System Problem
Do not have an OBD reader/tester yet (suggestions welcome) so have not checked to see if the same code P0035 has come up with the same above two warnings.
Would like to have any available info before taking it to the dealer for a scan, etc.
Post
by jayhaire » Thu Oct 19, 2017 4:39 pm
For simple OBD2 code reading /clearing /data, I picked up one of these:
https://www.amazon.com/gp/product/B005NLQAHS
I also have a regular hand-held one but always forget who I loaned it too.
ayau
Post
by ayau » Thu Oct 19, 2017 4:51 pm
Zyg wrote: ↑Thu Oct 19, 2017 4:35 pm
The rev match and emissions error are caused by a loose engine harness. It’s documented on Civicx.com. The official fix is to replace the harness with a newer one.
Zyg
Post
by Zyg » Thu Oct 19, 2017 5:46 pm
Thank You.
