98-0730 Salvage rebuild!!!
Re: 98-0730 Salvage rebuild!!!
Post by DC231 » Tue Mar 13, 2018 8:04 am
All year Integra Coupe window motors and Regulators are the same part numbers no matter what model so you don't need specific 98 to 01 window motor and Regulators you can use any window motors and regulators from any Integra coupe from 94-01.. the parts car is a 2000 model.
Misterjew
Post by Misterjew » Tue Mar 13, 2018 12:46 pm
Stin1 wrote: Tue Mar 13, 2018 12:50 am
Misterjew wrote: Sun Mar 11, 2018 12:45 pm
Cap wrote: Sun Mar 11, 2018 9:29 am Would this help?
www.speedofheat.com/images/integra/keyless1.jpg
I bought this harness on Facebook from someone who thought it was the dealer option harness for ITR keyless entry. When I got it, it was obviously not the correct part, but I kept it because I thought it might have the correct connectors that I could adapt to make a working keyless entry project. Now that I sold my car, I don't need this.
Look carefully at it: it has an ignition key and keyless fob. The fob says "Honda". So, I think this is a JDM door harness. Maybe these parts can help you.
That door lock module is different than the oem usdm unit. I have the jdm harnesses as well as the used ones. I believe the pinouts are different. I have my Haynes manual for the car but I've been having an issue locating a rhd diagram to compare. If I can figure out the wiring I don't see the need to change the regulator/motor. I will keep doing my research I also may need to stop by one of those "jdm" shops and ask a few questions.
This looks like the keyless entry available on eg jdm civics that used maybe used a different if or ir signal. The extra hole on the handle had them. Different handle than a eg. Integra or civic ek for sure on the handle. The lock box looks like my em1 box.
I used to always buy the modules and resell them on eBay it's been a while.
DC231 wrote: Tue Mar 13, 2018 8:04 am All year Integra Coupe window motors and Regulators are the same part numbers no matter what model so you don't need specific 98 to 01 window motor and Regulators you can use any window motors and regulators from any Integra coupe from 94-01.. the parts car is a 2000 model.
Can you test everything and get back to me? Also do you have the door lock actuators also. Lmk thanks
98-1147
02 BB S2000 OEM HT/17x10 Ce28/J’s Racing
Post by DC231 » Tue Mar 13, 2018 1:47 pm
sure I can.. it might be a day or 2 but ill get back with you for sure.. I assume the actuators are there as well but will let you know about that when I get back to you after I test the motors..
Misterjew
Post by Misterjew » Tue Mar 13, 2018 4:09 pm
DC231 wrote: Tue Mar 13, 2018 1:47 pm sure I can.. it might be a day or 2 but ill get back with you for sure.. I assume the actuators are there as well but will let you know about that when I get back to you after I test the motors..
Sounds good. Thanks
98-1147
Post by DC231 » Fri Mar 16, 2018 3:04 pm
I was able to test everything with positive results if you pm me we can talk about details.
Misterjew
Post by Misterjew » Fri Mar 16, 2018 8:56 pm
DC231 wrote: Fri Mar 16, 2018 3:04 pm I was able to test everything with positive results if you pm me we can talk about details.
Pmd you
98-1147
Misterjew
Post by Misterjew » Thu Mar 22, 2018 7:31 am
Quick update. I purchased the parts I needed from Kevin "dc231" let me tell you. I had the parts the next day. He packaged them so well they could of survived a fall from a plane. I really appreciate it. He even labeled the parts driver or passenger.
98-1147
Post by DC231 » Thu Mar 22, 2018 2:11 pm
glad to help 8-) .. there are some more parts available if anyone needs anything let me know and ill see.. lance please verify everything works on your end after installation I would really appreciate it.
Vtecwreck
Post by Vtecwreck » Thu Mar 22, 2018 2:24 pm
Glad you were able to figure that all out! Now let’s see some updates :beer: :beer:
Misterjew
Post by Misterjew » Thu Mar 22, 2018 8:55 pm
DC231 wrote: Thu Mar 22, 2018 2:11 pm glad to help 8-) .. there are some more parts available if anyone needs anything let me know and ill see.. lance please verify everything works on your end after installation I would really appreciate it.
I checked the parts prior to installing them and everything was fine. Driver side works passenger side has an issue but it's with the car not the parts. I'll get it sorted out before I die. I need to take some pics and update the thread.
98-1147
