98-0730 Salvage rebuild!!!
Misterjew
Re: 98-0730 Salvage rebuild!!!
Post by Misterjew » Sun Mar 11, 2018 12:45 pm
Cap wrote: Sun Mar 11, 2018 9:29 am Would this help?
www.speedofheat.com/images/integra/keyless1.jpg
I bought this harness on Facebook from someone who thought it was the dealer option harness for ITR keyless entry. When I got it, it was obviously not the correct part, but I kept it because I thought it might have the correct connectors that I could adapt to make a working keyless entry project. Now that I sold my car, I don't need this.
Look carefully at it: it has an ignition key and keyless fob. The fob says "Honda". So, I think this is a JDM door harness. Maybe these parts can help you.
That door lock module is different than the oem usdm unit. I have the jdm harnesses as well as the used ones. I believe the pinouts are different. I have my Haynes manual for the car but I've been having an issue locating a rhd diagram to compare. If I can figure out the wiring I don't see the need to change the regulator/motor. I will keep doing my research I also may need to stop by one of those "jdm" shops and ask a few questions.
98-1147
02 BB S2000 OEM HT/17x10 Ce28/J’s Racing
Post by DC231 » Mon Mar 12, 2018 9:38 am
I may be able to get you the motors and regulators from a friend for a good price. just don't know yet if the regulator is good on the passengers side(donor car was crashed)but I can let you know as soon as I find out. let me know if you might be interested because If you are I'm sure he will pull them asap.
98-0145
Post by 98-0145 » Mon Mar 12, 2018 3:25 pm
Window motors and regulators are completely different from rhd to lhd. Find an integra at a local salvage yard and swap the parts over. Any 98-01 dc2-dc4 should work just fine.
Misterjew
Post by Misterjew » Mon Mar 12, 2018 5:53 pm
DC231 wrote: Mon Mar 12, 2018 9:38 am I may be able to get you the motors and regulators from a friend for a good price. just don't know yet if the regulator is good on the passengers side(donor car was crashed)but I can let you know as soon as I find out. let me know if you might be interested because If you are I'm sure he will pull them asap.
I will most likely order a set off of eBay that way I have a 30 warranty if there is any issues. Thanks
98-0145 wrote: Mon Mar 12, 2018 3:25 pm Window motors and regulators are completely different from rhd to lhd. Find an integra at a local salvage yard and swap the parts over. Any 98-01 dc2-dc4 should work just fine.
I'll just order a set off eBay and do that. Do I need to get a set of actuators also? Thanks
98-1147
Post by Stin1 » Mon Mar 12, 2018 6:23 pm
Buy oem recycled parts. Cheap eBay stuff won't last. Sometimes they aren't even wired properly in the first place.
Misterjew
Post by Misterjew » Mon Mar 12, 2018 6:25 pm
Stin1 wrote: Mon Mar 12, 2018 6:23 pm Buy oem recycled parts. Cheap eBay stuff won't last. Sometimes they aren't even wired properly in the first place.
Of course not. I was going to buy a used set of OEM one's. I may just bring a small battery with me to the junkyard and test them before I buy them if I can find any
98-1147
Post by DC231 » Mon Mar 12, 2018 7:03 pm
I can test the ones my friend has and man I can get you both side regulators and motors for $75 shipped as long as you're in the lower 48.
Misterjew
Post by Misterjew » Mon Mar 12, 2018 10:26 pm
DC231 wrote: Mon Mar 12, 2018 7:03 pm I can test the ones my friend has and man I can get you both side regulators and motors for $75 shipped as long as you're in the lower 48.
Are they from a 98-01 model?
98-1147
Post by Stin1 » Tue Mar 13, 2018 12:50 am
Misterjew wrote: Sun Mar 11, 2018 12:45 pm
This looks like the keyless entry available on eg jdm civics that used maybe used a different if or ir signal. The extra hole on the handle had them. Different handle than a eg. Integra or civic ek for sure on the handle. The lock box looks like my em1 box.
Post by Stin1 » Tue Mar 13, 2018 1:25 am
Stin1 wrote: Tue Mar 13, 2018 12:50 am
This looks like the keyless entry available on eg jdm civics that maybe used a different if or ir signal. The extra hole on the handle had them. Different handle than a eg. Integra or civic ek for sure on the handle. The lock box looks like my em1 box.
