18160-P73-A00 (catalytic converter) discontinued. Looking for replacement.
Re: 18160-P73-A00 (catalytic converter) discontinued. Looking for replacement.
Hi. I build custom catalytic converters. Any length, any diameter. I typically use viberant performance stainless components. My prices start at $300 plus shipping. Pm me if you are interested.
Anyone have experience running a JDM Type R catalytic converter?
The jdm version is shorter . Both the two bolt flange and the three bolt flange are slightly larger. You need a jdm header and b pipe for it to bolt up. It also does not have a secondary o2 sensor . Instead it has some sort of temp sensor. Since the cat is shorter there is only one catalyst honeycomb vs the two in the usdm cat. You will probably get a catalytic converter below threshold code with the secondary o2 installed without trying to trick the ecu.9701TypeR wrote: Wed May 09, 2018 10:43 pm Anyone have experience running a JDM Type R catalytic converter?
Good info, thank you. I know what your referring to with the temp sensor as oppose to an O2 in the cat. Its probably a thermal probe or something similar. In regards to the cat being shorter and needing a JDM midpipe, Are you familiar with the length of the JDM headers 96-97 and 98+, Are they the same length as US?
I think 96-97 are the same length as the US header. The 98 spec header compared to my old comptech carb legal header was slightly longer, I dont remember by how much.
I've wondered about going to an exhaust shop and getting a custom 12 inch cat (jdm length) made and see if it would result in no check engine light, and even pass ca emissions.
Get the CARB approved magnaflow unit. I have one and it passes smog here in CA. I had the ends cut and converted to 2.5 to mate up with my jdm 4-1 Andy SMSP 2.5 cat back.
PY 01-964
Gt-350 or CTR in near future
Can anyone confirm the diameter of an OEM Acura Integra Type R cat? Looking at magnaflow they are saying 2" diameter, and if anyone can chime in about their experience aside from the flange not being correctly angled!
- oddomatik
- Badge Number: 98-0542
Another option for CA CARB legal is Walker part # 82506 - currently $600 on eBay. Any muffler shop can make it fit for a bill or two.
Here is the CARB search tool that can be used to locate a complete list of brands available.
https://ssl.arb.ca.gov/AftermarketParts/catalysts
First page of results had one for <$500 on eBay (Airtek)
Most I've seen are required to provide a 5-year warranty as part of the EO.
Print out the EO and keep it in an envelope in your glove box to make life easy for your smog tech.
SpecE30 | RAM 3500 | CB550
