FOUND--No longer looking
Looking for a good set of OEM Type R connecting rods. Will pay more for set that has been to a reputable shop and verified to be within OEM specs.
- Badge Number: searching
Re: WTB OEM Type R Rods
I know I have a set somewhere, I also have gsr rods (same weight/specs just use different rod bolts which can be switched out and checked by a machine shop)
Thank you! Please let me know if you find them and how much you would like for them. I have GSR rods currently.
When I found my VIN matching engine I was told it retained all the original rotating assembly and later came to find out that was not true. I found the proper crank yesterday so now I am in search of the proper con rods.
Please reach out to me at 904-414-0451
Will do, I'll check in the garage tmw and see what I have.
